jetboater4life
- Rochester, MN 55901
- X
- A) Engine wont turn over at all
- Shift Lever not in Neutral
- Move throttle to Neutral
- Wiggle throttle to make sure contact is clean
- Cleanout Hatch switches or wiring loose (swap switches/connectors if just one engine)
- Have someone stand on hatch and retry
- Have someone open hatch and manually depress buttons
- Tape a dime or nickel to hatch where button hits to temp try
- Adjust button height
- Blown Fuse
- Replace fuse under cap on ECU on back wall of engine compartment (should be a spare in there--replace spare!)
- Check fuse inside small black box near batteries, usually screwed to the divider wall. (Follow main +Positive cable from battery to find fuse)
- Corrosion on Negative terminals or loose terminals at the battery
- Tighten well
- Clean and apply dielectric grease
- Starter Component failure
- Check wire connections at starter
- Battery not fully charged (with a partial charge blower/radio may work, but there may not be enough power to turn the starter).
- Pump/Impeller locked up due to obstruction/corrosion etc -pull pump and see if impeller spins.
- B) Engine turns over but won't start
- Kill Switch at helm not seated properly
- Pull lanyard on and off a few times/wiggle it ect
- Swap connectors on back of switch if just one engine)
- Cleanout Hatch switches or wiring loose-a bad connection might cause the starter to stutter. A bad switch or mis-aligned connection will result in no cranking or sporadic cranking.
- Swap switches/connectors if just one engine
- Fuel tank empty
- Fuel Tank-water or contaminents in fuel or pressure is low
- Spark Plugs fouled or caps not tight
- Crank case filled with water and/or fuel
- Fuel Filter clogged or water filled
- Battery connections loose or corroded (yes we've seen it happen-turns over wont start)
- Damaged/Malfunctioning ECU
- Engine Codes and Code Symptom
- 01 No malfunction
- 13 Incorrect pickup coil signal
- 15 Incorrect engine temp sensor signal
- 18 Incorrect throttle position sensor signal
- 19 Incorrect battery voltage
- 23 Incorrect intake air temperature sensor signal
- 24 Incorrect cam position sensor signal
- 29 Incorrect intake air pressure sensor signal
- 48 Incorrect data transmission
- 54 Incorrect bypass valve motor signal
- 63 Incorrect intake air system signal
- 68 No wake
- Voltage State of Battery Charge
- 12.6+ 100%
- 12.5 90%
- 12.42 80%
- 12.32 70%
- 12.20 60%
- 12.06 50%
- 11.9 40%
- 11.75 30%
- 11.58 20%
- 11.31 10%
- 10.5 0%
