- X
Following up on an original post and lead from @itsdgm I recently found the gasket seal around the engine hatch, between the hinges from McMaster-Carr.
The original dimension of the storage closet seal were not exactly 1:1 for what I found, as a result the fitment was a bit tighter but easily manageable. The new part is black vs the original white. In the end it did not matter visually.
McMaster Carr part number : 1120a331 has a 3/16" edge and 5/8" rubber bulb. The image below is from current catalog page 3486, page 3487 has similar configurations but not as close as this one.
http://www.mcmaster.com/#catalog/120/3486/=se280z
My original seal was deformed to the point of free hanging in the engine bay. This job is a simple remove and replace. No glue was used or edges to clean up. The min order is 10 ft, I used about 3, enough left over for another 2 boats.
