buckbuck
- Texas
- X
I want to control the factory ballast bags separately (212X) by placing solenoid valves after the ballast pump, allowing me to lean the boat when I surf. I seem to recall someone (Cam?) saying you need a special type.
Anyone have insight on this? Will a typical 12vdc Asco solenoid valve do the trick?
