Would like to add an amp
Kevin M
Streetsboro, Ohio
I have the 2013 242 limited S. The radio head is the Clarion unit and I have six 6.5" polks all around with two tweeters in the tower. I would like to add an amp first, w/o a sub so I have a couple questions.
1. What amp do you guys recommend? Brand, channels?
2. I understand that by adding an amp, the sound will be soooo much better that I may not need/desire to cut a 10" hole in the side to mount a sub.
T h a n k s !
Kevin
octavio3311
Brookfield, Ct
I'd recommend a WetSounds HT6 and disconnecting those tower tweeters.
Those Polk's sound pretty freakin good once you put some power behind them. The sub is a matter of personal preference. I didn't feel I needed one, but went ahead and put a WS 10" IB sub in. And it kicks ass.
jawsf16
I have two pioneer car amps powering four polk 6.5s, 2 Polk 6x9s on the tower and a bazooka tube sub and they are awesome. Lots of ways to skin this cat...
tdonoughue
The Woodlands, TX 77381
I just added a JL 6 channel amp. I did the sub, but even without, it does make a big difference. I definitely agree that there are many ways to improve the stock system and the amp will be key to that.
There are lots of write ups on amp installs here. Do check those out for placement and type ideas.
