My wife broke the battery switch on our first trip out. Dealer is sending a replacement. Anyone have a link to a video of replacing the switch? Is there much to it?
Found one video. Looked like 2 terminal posts under the switch cover with nut and washer. Didnt get much easier than that. If it's more, please someone warn me, otherwise, as you were (thanks)
Its simple, just like you said. I did notice my bilge pump was on the switch and moved it to the battery direct connect, not sure why it wasnt installed that way. I want my bilge to work even when the battery switch is off. Make sure you have the positive removed from the battery when you install the switch.
