FSH 210 Sport
- Tranquility Base
- FSH Sport
I knew that I was going to need more switches and a source of power for those switches that would control the new bilge pump and the electric raw water wash down pump. I used the oem switch panel that held the cruise assist / no wake mode switch and the jet wash switch. I cut another Carling switch hole to the left of the jet wash switch and moved the jet wash switch to the new hole and put the cruise assist switch into the hole that held the jet wash switch. On the lower row, I cut two more holes and installed the switches for the raw water wash down pump, the bilge pump, and a spare… always install spares.
I bought two buss’s, a positive and a negative, I fed the positive buss with 10/2 wire connected to a 30A breaker. The breaker in turn would be connected to the switched side of the house battery switch.
By putting another buss in the head compartment and feeding it from the switched side of the house battery switch I could leave the OEM electrical system alone, so everything I add will be an isolated set of systems. This buss will also be the source of power for the hard tops‘ distribution panel that will come later.
