Unfortunately have a seized engine. Lined up an 06 fxho with low hours that runs well. Anyone perform this swap? I have an 06 ar230. Looking for any tips and advice on process.
@itsdgm@Scottintexas@buckbuck@Jgorm@cybuch
These are some of the most knowledgeable members who have done it and/or posted super useful, detailed threads (I'm missing several others - sorry).
I swapped an engine from a 02 FX140 into a 06 SX230, the only major difference was that the wiring harness going to the throttle body/air cleaner assy. I believe the skis have some sort of rollover switch that the boats don’t have. I just swapped the whole assembly from the boat to the new engine.
I thought that I did a write up on my engine swap. I’ll look for it. In the meantime here’s a step by step engine removal guide for a non ho engine. YOurs would be similar. Hope it helps.
Bad engine is starboard. How did you get by not removing the manifold, wouldn't it be easier to pull it out then swap everything being that I am installing with a new motor?
So you disconnected the whole wire harness before pulling the motor out then installed the new engine without the wire hanress and plugged it all in when the motor was in place?
I remember the service manual being very good at the step by step instructions for pulling. I left the exhaust attached and laid the ecm on top. It was not a difficult adventure.
So you disconnected the whole wire harness before pulling the motor out then installed the new engine without the wire harress and plugged it all in when the motor was in place?
@okula225 The engine weighs near 200 lbs. You need to have a crane set up. I needed to fabricate an aluminum gantry crane to do it. I suggest studying service manual before attempting to remove motor. It is easier if you do not have to contend with the weather. It is quite easy to run into unseen problems, like dropping or losing a bolt, etc. I say this not to discourage but help prepare. Starboard engine removal
