165 blower issues
Eddiefain
165 G
My blower just stopped on my 165g. The light on the switch doesn’t light up either
jb32566
Navarre, FL
165 ID
it's either a fuse or the blower itself is dead.
check fuse. if blown, replace. hopefully that's it.
if the fuse blows again, the blower is seized or shorted. you'll need to remove it to figure out which one.
if the fuse wasn't blown but it's still non operational check the connections. hopefully something just jostled loose.
post here with results.
if neither of those things fix it, i would start working my way back. most likely with just a voltmeter, but check those things first and we can work backwards from the blower through the switch and back to the battery if necessary.
ScarabMike
Green Cove Springs, FL
HO Impulse
^^^ This, alse check the connectors for corrosion.
Shane miller
HO Impulse
Has anyone thought to check the switch itself? I have power at my plug but the switch doesn’t illuminate and blower won’t turn on.
Cs419
Maumee River, Ohio
I got the same thing with no blower but also no bilge pump. Checked fuses yesterday but going back and will check what jb32566 said & switch. I also heard that the fuse distribution box could have internal issues. Going to knock it a few times with a wrench. Possible open it up and see what's going on inside.
