Wesley Cobb
- 242 Limited S E-Series
Was reading through an older post concerning water in the clean out ports and guys resealing the access panels on their boats. After reading the post and the many diverging discussions, I was still left with my question. Should I be concerned with the clean outs being partially or completely filled with water at the end of the day? Plugs rotate/remove relatively easily. I do not see any damage. I am constantly reaching down into flooded clean outs when I pull the plugs at the end of the day. I dry store the boat on the rack with them installed. Is the water getting pushed through poor sealing plugs? Seems the only logical conclusion since the upper deck is dry. Should I store the boat with the plugs out?
