Ibeflyinhigh
How many of you have cold start issues on your 195 and how many dont?
I've got a 2022 195 and the very first time I fired it up took 8 times until it would stay running. The idle is super erratic also bouncing around from 600rpm up to 1400 only when the engine is hot does the idle settle down. Maiden voyage took 7 times starting before it would stay running. This cant be normal. Air temp was 80 degrees when I took it out sunday. I've talked to many pwc guys who say they dont have the issue with the svho. I'm going to check coil plugs and oil level but I dont think thats the issue. I put stabalizer in it and fresh 91, didnt help.
