195 HO Impulse Main Battery
Joseph Baxter
HO Impulse
OK....I broke one of my most important rule....wire labeling. So I removed the batteries for storage and did not label the cables. I see the positive (red) and I assume the rest go on the (-) of the main battery as they are positioned on the side the (-) would be with battery in. Can anyone post a pic so I do not fry anything. That would real be bad!!!
Murf'n'surf
Naples Florida
Maybe you could post a pic of what you have --- we might be able to help that way.
Joseph Baxter
HO Impulse
Pretty sure the wires in the left of the pic are negative and the only positive is the red which is labled as such.
Joseph Baxter
HO Impulse
Thanks @ScarabMike .....I completed the new amp install after removing small kicker sub amp. Just need to hook up batteries for op check.
Joseph Baxter
HO Impulse
@ScarabMike ...just saw a picture you posted on another thread that was actually of my battery and the wiring...I got it handled so no need to post anything.
Joseph Baxter
HO Impulse
No worries....I should have noticed it before and I totally forgot I put that pic up.
Jpseph296
long beach island nj
HO Impulse
what size amp did you replace the stock one with? did you keep the factory sub?
Joseph Baxter
HO Impulse
I bought an Alpine MRV M-500 mono sub amp. It is compact enough to fit with the 2 existing kicker amps. If it is not raining Thursday I will get in a grab a pic. Currently the only configuration I can get relates to 300W of the 500 due to the 8" speakers. I got a second 8" 1 ohm and installed it opposite the stock one so yes they I did keep the factory. My better half already complains I have spent too much money. They absolutely pound and no more distorted bottoming out bass. If I had it my way I would get the Alpine MRV 300 for the rest of the speakers. The amps are really decently priced.
Jpseph296
HO Impulse
That's awesome man I might have to try this now can't wait to see some pics of the install thanks
Joseph Baxter
HO Impulse
RFScarab
Folsom CA
HO Impulse
Cool! Send some pics of the sub installed across from the stock one. Cutting boats kills me but has to be done. Considering doing the same. The wiring in these things scare me lol. What direction did you run the wire to the new sub?
Joseph Baxter
HO Impulse
Will do! I had the dealer do it and he said it was an absolute pain. Had to go real slow and take breaks. I would have an installer do the sub mounting for sure if you are not used to it. The speaker wire runs from the port side at the amp to the back around the engine compartment to the starboard side new speaker. Of course due to dual voice coils I had to wire it a certain way. I can include a diagram with the pic I send later. I did not wrap the wire in the shielding but I did wire tie it between the existing wiring that is wrapped in the engine compartment. Hopefully that will not come back to bite me.
Jpseph296
HO Impulse
Yes they look awesome any info on the install would be greatly appreciated
Joseph Baxter
HO Impulse
Ok I will write it up and get some pics too.
RFScarab
Folsom CA
HO Impulse
Those do look good. Just hate drilling in the boat. Can't wait to see some close ups to set my mind at ease. I'm sure you will address in your write up but tell us did you wire to a separate switch or tie in to existing switch on the dash for interior lights? Thanks man looks cool.
Jpseph296
HO Impulse
Yes that's the one thing that I fear is drilling below the water line on a brand new boat lol
