Any idea where to get 2004 SX230 snap-in carpeting? Looks like you can still get 2007-2009 on eBay but the 2004 doesn’t fit that. Looks like snapincarpet.net can do it for $603 but looking for cheaper options.
Keep an eye on eBay. Do you have your old set? It may be able to be used as a template locally to be replaced with carpet. This is $285. https://www.shopsbt.com/jetski/Yamaha-Interior-Traction-Mat-AR-230-HO-SR-SX-05-06.html competes with hydro turf, might give you 3-5 good years before it needs to be replaced. (I cannot describe with words what a royal pain the @$$ it is to remove, same as any other glue backed product, probably 15-30 minutes per square feet) SeaDeck would be nice too, just a bit more money than this cheap option. (made me look, it's $800 for Cockpit) I had hydroturf on my old boat for 2 years and it held up great while I had it. Can't speak for longevity, and SBT stuff is like hydroturf knockoff, so I can't speak to its long term performance. Money is worth different to different folks, so the very best may not be the best for you..I certainly feel like a cheapskate sometimes on this board, as I'm asking for and looking for more economical options to some of the more accepted upgrades for our boats. I think that's half the fun! Best of luck whatever you choose.
I need something in mine too. Custom carpet is probably 1000. That $275 option looks pretty sweet! It uses a peal and stick pressure sensitive adhesive. It could work great, or fall off!
I mounted the Hydro Turf cockpit kit on marine-grade carpet with the kit's adhesive backing and installed snaps to snap it into my cockpit's original snap-in carpet location. It's holding up great in the Arizona sun, I can easily remove it for cleaning, and I won't have to try to unglue it from my deck in a few years when it's time to replace the mats. I do wonder, though, if there's a better choice to attach the mat to than marine-grade carpet. You need a backing material because the snaps will pull through the mat material without it (I tried). Thoughts?
I've been looking at doing something similar, but my backing material of choice would be something that is closed cell, so that it does not absorb water. As you have it, when it gets wet it's going to smell, and I don't think it will dry as easily as the carpet did before, as the Hydro turf will "protect" the water inside the carpet. Maybe something like a rubber mat or even Astro Turf upside down could be used as a water proof backing so it does not absorb water?
Hi,
I'm looking to replace mine too. Can't find carpet for 2004 SX230. Ordered new mats for swim deck but want carpet for cockpit. I got an estimate from one of the recommended vendors on here; $900. Found some vendors online selling but not sure it will fit the 2004. Yamaha sports plaza,
F1C-U3908-31-00; 479.08 plus shipping. May order that just not sure it will fit. Be nice to have measurements of that to compare to mine. Did you have any luck?
