kjr6306
- SX
Went to do an oil change and found milky oil in the right engine. Drained all the oil via the rear drain plug and getting ready to add new oil and filter. Been reading through a million threads on this issue and need to start troubleshooting. All the plugs looked good and had uniform coloring so don't suspect water is getting into the combustion chamber. Going to do a compression check shortly but wanted to get this thread started and see the recommended order of items to check obviously from easiest fix to the hardest. After reading the threads I am suspecting the exhaust manifold issue. Is it possible to remove the right engine exhaust manifold with the engine in the boat? Is there a write-up on the procedure posted? Any help is greatly appreciated.
