Tyler83
- Limited S
Hey guys wondering if you could help me out. Just bought this boat and went to install a new Fusion Apollo 670 in it and found the factory stereo harness looks to be gone. Like has been cut out. The previous owner powered the Kenwood head unit off of the power and ground to the cheap amp he had under the helm. There are lots of cut wires under the helm but I cannot seem to get 12v from any of them. So couple of questions
Do these boats have a constant 12v wire and a 12v ignition wire to over the head unit?
If so, what color should they be? And if ithey don’t have power where should I look to rectify that?
I found a 10ga power and ground wires running by their selves from the house battery to the panel where the switch for the navigation lights etc are located. Is this factory? I figured if it were they would be in the main harness.
I may just start from scratch as I am also installing 2 wet sounds amps and 6 wet sound revo6 speakers.
trying to attach pictures of what I’ve found to give you an idea of what I’m trying to clean up.
