2011 AR240 Driveshaft/Impeller Tool
Jeff_F
Kennett Square, PA
Posting this because I searched everywhere and couldn't find the answer.
The service manual lists the tool for holding the driveshaft, needed when replacing an impeller, as Yamaha YB-06201
The Solas tool (which is the most readily available one) is WR014H.
Some sources I found listed it as WR014H, some as WR007H, so I bought both since they are pretty inexpensive and I wanted to get the job done. Solas Tool.JPG
Trm1765
Red Wing MN
Limited
It is not the WR007H,, that one is to small.. I'll try the other one. :)
