Ron and Renee
- Cookeville TN
- SeaDoo
- Challenger
It could have been something tiny. Even a small stick, toothpick, etc.Weird though the first time it was in open water and can't imagine what could have gotten in there.
Sounds like your port side pump is cavitating, pushing air instead of water, if that happens it will rev up all the way until it hits rev limiter. You do not want to let it happen too much as it will cause severe damage to metal surfaces of impeller and such (aka cavitation/ventilation burn).Took the boat out again today. It was fine all day until just before we went in. Once again wide open water and bad vibration this time on the port side motor. I tried everything to clear it but in higher RPM vibration was really bad. Weird thing even though the two engines were synced the one that was vibrating would run over 8000 RPM while the other was only running 6000 RPM. Any thoughts? Thanks Ron
