3 green tornados
- Southern CA
- 212X
Ok guys I dropped the money on the 2017+ wakebooster knowing I would likely have to alter it although the guy at the parts counter said it would fit. Here are the pictures of what I did and the approximate measurements of the cuts I made.
I used a 18v Mikita battery powered hand held router with a 1/4 bit and a 1/2” drill bit in the drill so I did t have to do a plunge cut.
I followed the same angle as the cut outs for the tie downs that come machined into the wakebooster.
Here are the pictures.
PM me if you want to give me a call and talk about it.
The final picture is of my brother in law, only surfed a couple times. Wake booster installed. We also have factory ballast full, 400lbs on top step, 400 lbs on seat behind the helm and my dad (guessing 350ish) on the port side corner. This was our very first run and we ran out of kid free time before we could try to many set ups.
P.S. don’t tell my wife how much they cost and I cut it to make it work. J/k she knows
