Hezi
- Secaucus NJ
- 212S
This is the conclusion of a thread I started here:
https://jetboaters.net/threads/at-what-point-an-impeller-duct-needs-replacement.18607/#post-322342
At 55 Hours, my boat performance degraded to the point I had to remove the jet pumps and inspect. I ended up overhauling the pumps (excluding the bearing). This post is to help whoever wants to do the job themselves.
Shopping list:
Here are the parts I got from powersportsparts4less.com I found them from a post a user here recommended and they were cheaper than all the sites I Goggled. Moreover, they messed up on my order and to make sure I am getting my parts on time, they air shipped it to me at their cost (thanks Jeff). http://shop.powersportsparts4less.com/fiche_section_detail.asp?section=1096161&category=Boats&make=Yamaha&year=2015&fveh=29423 It was a little hard to get them and I ended up figuring out this is browardmotorsports.com the Hollywood location. Here are the parts. I used them all except 2 O-rings which are part of the bearing I ended up not using (red x).
Chemicals and more are as follow:
Permatex 51813 to replace Locktite 518
Permatex 59235 to replace Locktite 572
Locktite 242 (blue)
1 tube of Yamalube Molybdenum Disulfide Grease from eBay
Maxima 80916 Waterproof Grease to replace Epnoc Grease (thanks @boudin !)
A can of brake cleaner to clean surfaces.
Scotch Brite pad to gently clean surfaces
Solas WR014H Impeller Shaft Holder
Other than that I would have:
* A 6 points 27 MM wrench for the impeller (I used 12 points and it was fine).
* Torque wrenches that adjustable to the specific task (I used a large for the impeller and large screws and a smaller one for smaller screws per the book).
* Metric Allen keys, sockets, and wrenches.
* A 30 mm + ruler (to calibrate steering and gate position at install).
* A wire brush to clean old sealant from screws.
To remove the pumps, first remove the two “skid” plates under the pumps. You will need the room to put a flat screwdriver between two tabs to pray the pumps from the transom plate.
Remove the gate cable (slide rod cover over the ball joint to disconnect w/o removing screws). Remove rod connecting pumps to articulating keel, and remove steering cable.
After that, you have four 14 mm and one 10 mm screws and the pumps are out.
While the pumps were out, I cleaned and replaced 2 O rings on each pump for plastic filter, cleaned replaced the grease, and replaced an O ring on the bearing cones, replaced impellers, wear rings, and anodes. The manual is very clear on how to adjust the gate and steering.
2 pointers worth mentioning; when I removed the 4 14mm screws holding the pumps to the transom, it was very hard. Trying to install the pumps, the screws wouldn’t screw in the holes. I found lots of aluminum shaving in the holes and thought I may need a new transom plates. I didn’t feel like going and getting a metric rethread kit and was very close on giving up and taking as is to a shop to complete the job. Instead, I tried screwing the 8 screws to the holes. I ended up with 2 that wouldn’t go in. Upon closer inspection, I realized the thread on those screws grew somehow metal on the tip and clogged the thread. It was like someone welded a small dot of metal smack on the thread and this was what stopped it from screwing in. I took a small and fine metal saw and just re-grooved the thread in those spots and all was fine! Another pointer; when installing the aluminum plates under the jets, I used power tool. The trailer was interfering with the tool and I initially screwed the allen screws by hand before using the power tool. On the last screw I got lazy and use the power tool and skip the screwing by hand part. Don’t do it! I killed the thread and this last screw cannot be tightened ever again. I just put a bunch of silicone in and over it to hold it in place.
All the rest you can figure out from those pictures;
Shopping list:
Locktite 242 (blue)
