  • Gantlin Products, the creator of the WAKE WEDGE is currently running a Group Buy for those of you that want a better, cleaner wake to surf behind your Jetboat! This Group Buy expires on April 1st, so get your order in ASAP to jump on this once a year discount on the Wake Wedge. The discount could go as high as 15% off!
    (You can click the X in the upper right to dismiss this notice)
2015 AR240 Bow Light Replacement
Jonathan Pisarczyk
Ratings
25 1
Canada
Hello Everyone,
Just thought I would post on a bow light issue I had with my 2015 AR240. I hope this can help someone else. I replaced my OEM Bow light with a new LED assembly. The OEM light design is terrible. The bulb can easily slide out of position. I also noticed on the new 2018 model they now use the same Attwood LED model I purchased on Amazon. The holes basically line up. I had to make the holes a little larger with a drill bit. I couldn't find a white LED replacement. However the new stainless steel/black design looks better than I thought.
See link and pictures below:
Attwood LED 1-Mile Deck Mount Navigation Bow Light, Stainless Steel
https://www.amazon.com/gp/product/B001O0DIA4/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
Scottintexas
Ratings
2,120 43
Corinth, TX (DFW)
thanks for the links and pictures, added to the FAQ under boat mods/upgrade electronics, LEDs...
