2015 connex amplifier remote wire
Hezi
Secaucus NJ
I installed 2 JL amplifiers and was hoping anyone could tell if there is a dedicated wire coming from the head unit for amp remote. I could install a switch, but if the wire exist, It'll be much better. What do all of you with upgraded audio are doing?
Thank you for your help!
Mike Clark
Germantown, ohio
I’m sure you have this figured out by now, but in case you haven,t the remote wire is the dark blue one in the main harness with the speaker wires. I am running two amps and basically ran two wires off this one to both remotes connects on the amps. Turns on everything when I turn on the connect screen
Gto this website, provides complete manual for Polk Audio system on our boats. Once there, go to page # 9 for wiring identification.
WWW.manualslib/manual/609375/ Polk-mono-PA450
Hezi
Secaucus NJ
Thank you for this. I did figure it out and connected the blue to fire both of my amps. This should help other. Thanks again!
