2015 Scarab 165 - won’t start
Nedwod
Florida
165 G
Engine won’t start. Not sure if the engine is seized or starter is fried. How do determine which?
Thanks
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
You assume neither and check the other stuff first. Because both of those failing are way less common.
Does anything click at all when you turn the key? Do you have power? Are things connected correctly (battery)? Is the battery good? What is the voltage? Does it have the correct cranking amps? Is the master switch on? Is your emergency kill lanyard correctly installed? Is that emergency switch working? And finally, are your relays good (two of them, located inside the fuse box right beside the battery, those are very common problems for this issue).
Sorry, but I've been helping a lot of people here. I don't think I've seen anyone have a seized engine or failed starter since I've been doing it. It's usually the rest. It's very possible you've checked all of this, but such is the internet. We get people from all kinds of backgrounds, some with very little knowledge. What seems obvious to one isn't obvious to the other.
Report back with more info and hopefully we can guide you further.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Also, history of the boat probably matters since you haven it listed as 2015.
Nedwod
Florida
165 G
All of these issues/items check out OK. Radio/dash lights all work, battery good (new), master on, can hear the starter motor clicking, lanyard and relays are good. 17 hours on the engine.
Any other suggestions? Thanks Luc.
Judge
Cape Coral, FL
275SD
Was the engine rebuilt / replaced with only 17 hours on it?
Clicking can sometimes mean a loose or bad ground. I would take a heavy duty battery cable and connect one end to the negative battery post and the other end to a solid part of the engine block to establish a good known ground and then try it again.
If that doesn't work, removing the starter and seeing it is will spin up outside the motor might be your best bet. If you can get at it, you could try taking a jumper cable from the post on the starter and then holding it to the positive post on the battery to to by-pass any solenoid / relay to see of the starter will spin. Just be careful of hitting the block in a tight space.
Nedwod
Florida
165 G
Thx. I'll give it a try. The engine is original - just sat for over 18 mths in a garage.
