2015 Yamaha White Gelcoat
JimmyUSN
PA
Sharp corner on slip, wife guiding us in.:arghh::banghead:
I have quarter size chunk of gel coat missing by my swim deck. Does anyone know what the color is for white on a 2015 SX210? I will post pics of the repair job.
greg
Sanford Florida 32771
Glassman
Redondo Beach, California, U.S.A.
yeah, that'll wor....oh wait, did you say "Chunk"? that says it's for nicks, scratches, holes....:confused:
JimmyUSN
PA
It's about 1 inch triangular shaped, about 1/8 inch deep in the center, gel coat is gone, I can see fiberglass. I have a piece of aluminum tape over it right now to keep it dry.
Englewoodcowboy
Ceres, VA
That kit should work. Be sure to clean the area well with acetone, when you mix the gel and lay it up get some clear cellophane tape and cover it. If it is on the side it will try to run out and the tape will hold it in till it cures, then you can wet sand it smooth and buff it out. You can also get with your local yamaha dealer and get a patch kit with factory gel coat as well but I do not think it is that small a quantity.
I found a few bless on my boat on the engine hatch cover where they attempted to repair it at the factory and it looks like crap. Once I spotted it I keep seeing it every outing so it will give my dealer something to do this winter...
Some pictures and something for reference will help us give better advice. As @Glassman hinted at if it is too deep you may have to put a little fiberglass filler in there before the gel coat.
JimmyUSN
PA
So is the gel coat repair kit real runny?
Englewoodcowboy
Ceres, VA
It can be. My dad just always prepped everything and made a trough with tape then applied the gelcoat then taped it closed over the repair. He said it does a few things, first gelcoat is a resin and when you sell it it allows the natural wax inside to come to the surface. Glass with no wax in it when dry is always tacky to the touch. Then just make a block sander and gently work it flat, use 300 grit etc and once flat then you can hit it with a buffer and some 3m policing compound and if the color is an exact match, the repair will disappear. If you are worried about it you could always take it to your yamaha dealer, if he is a boat guy he will have someone that can do the repair and it should not be too expensive. A couple hours is all.
JimmyUSN
PA
Thanks, I am kind of anal, with DIY skills, just never tackled this kind of project yet.
My 1st year with a boat, that's not made of steel and has jet aircraft on the flight deck.
I did however, zip tie an old bumper to that sharp corner on the boat slip.
