2016 ar190 tower height and position
rick marzen
hey guys, I'm getting a custom tower made for my sx190 and was wondering how tall the forward swept factory tower is from the floor? Also, I was wondering how far the front of the tower is from the rear of the windshield? Anyone that can help would be appreciated.
Irvs
SX192
I think you're better off going to your local dealer and measuring things yourself... :)
haknslash
Lake Martin, AL
Moomba
I will get the measurement for you this weekend if we take the boat out and if no one else has responded by then. Forgot about this thread or I would have done it for you last Saturday.
rick marzen
Thanks a lot. I appreciate that.
haknslash
Lake Martin, AL
Moomba
I haven't forgot about you @rick marzen before leaving for the lake today!
Here's the measurements:
From floor to bottom of top tower surface approximately 73-1/2"
From rear of windshield to front of tower mount base approximately 4-1/4"
Irvs
SX192
Do you have a sketch of what the tower will look like? How much $ is the custom tower going to cost you?
I ask because after a VERY long internal debate of what tower to buy, I almost bout an OEM tower, I pulled the trigger on an Aerial Freeride for my 2015 SX192. I have a feeling that it might look a lil weird on the boat so I am ready to take it to a shop should it need to be modified in any way.
rick marzen
Thanks for the photos. If you have a chance, and think of it, the only other measurement I needed is the front of the tower to the first mount on the boat. Like a plumb bob from the top of the tower, measure from the hanging string to the mount? Thanks again
@Irvs , the tower is from Samson sports. Called the harpoon tower. Then he custom makes it to your boat and your specs. 2500$ plus shipping on a truck. So it's more $. One piece tower, very strong. Other towers are multiple pieces, ship ups. No sketches available now. Maybe later. You can't buy a Yamaha OEM tower. They request a hull I'd # for replacement towers. Already tried. Hope this helps.
haknslash
Lake Martin, AL
Moomba
I'll try and get you that dimension next time I have the boat out.
2kwik4u
Georgetown, IN
I've got the tower up in my garage currently. Walked out and measured this for you.
Dropped a plumb from the front of the tower to the floor. Then laid a straight edge across the front of the tower mount and measured between the two. This is probably plus or minus an inch or so.
rick marzen
That is awesome, I appreciate it so much. Now I can order the tower.
2kwik4u
Georgetown, IN
No problem at all. Good luck with the new tower, and be sure to throw some pictures up when it's installed!
haknslash
Lake Martin, AL
Moomba
Tower looks great @rick marzen! Very close to an OEM look.
2kwik4u
Georgetown, IN
AWESOME follow up post. That thing looks great. VERY VERY close to the OEM look.
Well Done Sir!
