2016 SX 190 Engine RATTLE
TiMaH
Ancaster ON, Canada
Good Morning JBers.... quick question.
I just bought my brand new 2016 SX190 and went thru the engine break in period religiously. Yes this Canadian couldn't wait for 80 degree weather and choose to accept the 50 degree frigidity....piece of cake.
Anyway.....took her out and allowed the engine to warm up for 15 mins at 4000-5000 rpms. (Yes overkill).
While going to WOT the engine was rattling like someone was shakng bolts in a tin can.
This sound lasted about 2-3 seconds during speed increase and then stopped .... normal engine noise ensued.
I did not notice this sound during the break in period.
I was able to achieve approx 40mph at 7700rpm. No issues. So I'm assuming plug was seated and no obstructions in the intake.
I thinking an engine mount....But really a brand new boat ?
Could you folks chime in here plz.
This is really bothersome....
Cheers
swatski
North Caldwell, NJ
Can you try to record the sound, it would help a lot. It could be normal, these boats are LOUD, and they can sound like there are loose bolts inside, can be a bit disturbing if you are not used to it. But the guys here should be able to tell (what they can hear).
4x15mph
Downingtown, PA
Check the jet pump nozzle deflector and make sure all bolts are tight to spec. It is probably fine but that is one idea around rattling
haknslash
Lake Martin, AL
Moomba
Also check for any debris or loose bolts, nuts, washers etc in the engine hatch and bilge. Sometimes when they make these boats they will leave a few extra hardware pieces behind.
Did it only do it once and fine since then at WOT? Check the oil level before heading out?
Bruce
Royal, AR
When something is stuck in the jet cavitation will cause extreme vibration and noise. I wonder if something is in your jet pump.
swatski
North Caldwell, NJ
So, was the sound bad for only 2-3 sec? If that is the case you almost certainly were just passing a piece of debris through the pump. As @Bruce said - a tiny piece of debris, like a wood chip, stuck in between an impeller blade and the wear ring inside the pump can cause dramatic vibrations.
TiMaH
Ancaster ON, Canada
I probably will not be out again till next weekend......still 60F or so "up" here in Canada.....
Ill attempt to reproduce the sound again and record it.....
Oil level was checked b4 my last outing and was at exactly 50% (in between "dots" on ds)
I didnt have a chance this eve to check the jet pump nozzle and surrounding area.....but I will look 2moro after work as well as determine if any loose articles exist in the engine housing area....
After 10-15 mins or so warm up.......I slowly went to WOT.....say about about 5 seconds to WOT.......
The sound was unnerving to me.........It sounded similar to this at the 25-30 second mark of the clip......my rattling was much more distinct (vs muffled), louder and much less engine throttle background noise.
https://www.bing.com/videos/search?q=rattling+sound+from+boat+engine&&view=detail&mid=81FBC0B813C35A87D69681FBC0B813C35A87D696&FORM=VRDGAR
As stated the rattle lasted for 2-3 seconds at the beginning of WOT.....on every occassion - say 5 or 6 times.....then no issues.
Can I hook up the engine to a water supply and see if I can repeat the sound on land/trailer ????
Thanx guys I truly appreciate your insight here......
Bruce
Royal, AR
Since there is no resistance when the jet is out of the water you do not want to rev very high on land. Full throttle on land could result in a louder noise.
TiMaH
Ancaster ON, Canada
WOW........common sense should have told me that - TYVM........
njmr2fan
Augusta GA
our motors are LOUD out of the water when rinsing them off. It unnerved me and I posted a video too. After hearing other 190's im much more comfortable.
swatski
North Caldwell, NJ
TiMaH
Ancaster ON, Canada
FINALLY was able to get wet this weekend with SHEWHOMUSTBEOBEYED and my parents.....
So 4 adults and Murphy the Dog....full tank of gas and lunchables.....
Could only make 38 MPH at 7700 rpm...........BUT NO "can of bolts" ratting....
So Im guessing swatski probably called it with minor obstruction in the impeller....
Thanx guys .... feeling a wee bit more at ease.....
Racerx805
Mine was rattling but upon further inspection the bolt and washer the holds the rear pole light came undone plus there was a few nuts and washers in the hull. (a magnetic stick through the wet locker access ports will do the trick)
