2017 242 limited S E rpm matching
kinglenario
I just bought this boat new. Overall I love it but having a couple of small issues.
When I test drove my boat I got it up to 52mph I think. I took delivery two days later and top speed is about 46mph with just me in the boat.
At full throttle one motor is significantly lower rpm than the other in both sync mode or not. This pic is full throttle. Should I just take it back to the dealer?
swatski
North Caldwell, NJ
100RPM difference (higher on port engine) is expected at WOT. That said, your RPM is a tad low-ish, but not by much. It will loosen up a bit with use. Was it warmer weather when you tested today?
kinglenario
Ok, good to know. The weather was almost identical. What should the RPM hit? The boat has about 3 hours on it I believe.
swatski
North Caldwell, NJ
7,400-7,500RPM is about the max f0r most boats, but in winter months you can get another 100-200RPM bump (when it's cool and dry). Ribbon delete will get you another 100-200RPM.
But I would wait a bit, your engines are not even broken in yet.
Pinhacker71
Verona, KY
242 Limited E-Series
That's about what I get on mine with 38 hours. A little disappointed. I also got higher rpm and mph when first took it out. Also some ribbon delete. Not sure what is going on.
swatski
North Caldwell, NJ
Weather is a big factor. After ribbon delete I'm running 7,600-7,800RPM WOT when it's cold - 50+mph. Basically, riding on the rev limiter or so close to it.
Here is a clip of a crispy cold and dry December ride - air in the low 40s, water in the low 50s - WOT run at 50+ as long as I want to go.
But on a day like today - humid 80 deg air, 75 water - 7,500-7,600RPM and 47-48mph at WOT.
Yamaha does all their "testing" in the Winter (go figure).
I'm assuming the E-series are regulated the same as far as the ECU tuning, but that could also be a factor. I know that the reverse RPM is different and it is way more restrictive in the Es.
