2017 AR195 Impeller question?
SnowSnob
AR192
So my 70year old father just purchased a 2017 AR195 on friday, well he took it out and sucked up some rocks the next day on saturday, so since im the one stuck working on this where is the best place for impellars and parts and do i need a socket to do this? I used to be big into jetskis and know alot but all the companies i knew for jetskis they dont seam to have parts for these boats?
Priceisright
Columbus
Did you have any luck? I sucked up a snake and think I did impeller damage
SnowSnob
AR192
Well no one here helped out but with a lot of banging my head against the wall I found a company called impros.com that knew exactly what I needed for the boat world, it’s pricey but I know have a stainless solas impeller pitched for a boat, just call them and tell them what u have and they will do it, also learned of u need a new housing which I did not need mine was still fine but you can get an aftermarket on me with a replaceable wear ring so if it becomes a comin problem u can get your solas impeller redone for less than new and then just put a sleeve in rather than replacing the housing everytime, u do need the holding tool so u can put the shaft in the vice and it’s backwards thread, hope I was helpful
and solas told me if I know what pitch I need they can make one but Idk what pitch I needed and impros knew what I needed and I Will do business with a helpful company
SnowSnob
AR192
Jet boat impeller.com was another one bit no one answers the damn phone and u can’t leave a message and when you email them the respond 3 days later
Way_too_many_kids
If you had to change the housing which one would you replace? Oem parts list is showing two housings.
