1. Welcome to Jetboaters.net!
  2. Heads up! We are fortunate that Justin at Ridesteady is offering members here a discount to his Speed Control Solution, so check out the Ridesteady Speed Control Discount for JetBoaters.net members only.....you only have Until JANUARY 31st to get in on this discount!
    If you are looking for a speed control system similar to Perfect Pass, but much easier to install with better features, you will want to check this out! I used to call Perfect Pass a marriage saver, I think you'll find RideSteady even better!
    Thank you Justin @RideSteady for offering this exclusively to JETBOATERS.net members!
    Dismiss Notice
2017 AR210 Display and Tachometer malfunction
Discussion in 'Yamaha AR210, SX210, 212X & 212SS' started by MoreFunWet, Jun 13, 2017.
  1. MoreFunWet
    MoreFunWet New Member
    5
    Ratings:
    +0 / 1
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    New year, new model or reborn model.. I think I should have waited to see if there were kinks to be worked out.. anyway.. the boat has only been in a fresh water lake, after one long weekend I noticed as soon as I switched the battery on the tachometers started to bounce...0 to 8 and 8 to 0... Nice easy rythm... Good for music, not so much for a boat... Went to fire her up...and as before, fired right up but the needles didn't change and the display was totally dead... It's in the shop, I assume it's a bad display but not sure it's a good sign that it's in the shop with less than 100 hours on it... I'll update when I know something more.
    • Bummer Dude!!!! Bummer Dude!!!! x 1
  2. Brent Compton
    Brent Compton New Member
    5
    Ratings:
    +1 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    My 2017 AR 210 just experienced the same problem today. I have no idea what's going on, did they ever tell you what was wrong with yours? Everything was working fine and then it wasn't. No loose wires or bad connections from what I can see.
  3. MoreFunWet
    5
    Ratings:
    +0 / 1
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Brent... I totally forgot about this post... The whole situation was borderline fiasco with the dealership... BLUF.. it's fixed and it was the display computer... It is not the tachometers... It is not the signal coming from the engine... But the display computer 100%.. they ended up replacing the unit and it works normal again.
    They had no explanation as to why .. just replaced it.
  4. Brent Compton
    5
    Ratings:
    +1 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Appreciate the reply. Guess I'm taking it back to the shop.
  5. Peter Alonso
    Peter Alonso New Member
    13
    Ratings:
    +7 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    My New 2018 SX210 with 5 hours did the same thing!!!!! I’ve spent a two weeks searching for similar scenarios until now! Taking the boat in for service on Sat. Hopefully the symptoms continue at the dealer so they can replace the unit .
    • Optimistic Optimistic x 1
  6. Brent Compton
    5
    Ratings:
    +1 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    My dealer had to replace both tachs and the display screen which took 2 months to come from Yamaha. SMH! Hope your boat gets fixed faster than mine did.
    • Like Like x 1
  7. Peter Alonso
    13
    Ratings:
    +7 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Thanks
Share This Page
