Chucksx190
- SX
Hope someone can shed some light on this issue for me. I have a 2018 sx180 with 87 hours on it. It is used in salt water but has a 15 mile ride home in a fresh water river and is flushed with salt away every outing as soon as we get it home. It is stored on a lift out of water. I took it out today got it about 12 miles out, for the last 2 miles I was wide open 7700 rpm 44mph most of the 2 miles. I slowed down for a 5mph zone and about 5 seconds later the check engine light came on and over temp was flashing. I looked at the pisser and it looked fine so I shut off the engine. I always carry my snorkel, goggles and a dive flashlight. So I jumped in the water and checked the grate. It was all clear. Next I looked in the jet nothing in there and the water feed screen was clear also. So got back in the boat about 15 minutes had passed so I started it up. Pisser looked normal so I started off again. About a minuet later the engine light went off and over heat flashed. opened the engine compartment and the manifold was warm to the touch and the pisser was working. So I quickly shut it off. A minuet later I restarted it and steam and water came out of the pisser (not boiling normal flow with steam also) its 75 degrees here so its not just water vapor. I turned it off again waited 10 minuets. Started it up reved it up in reverse then forward did this 3 times then turned around and headed home. No more alarm and I went all speeds from 5mph to just over 40mph. Got it home and pulled all water hoses off one by one started the engine and all hoses had good water flow. All hoses and where they attach were clean as new with no corrosion. Has anyone seen this? I have the 5 year warranty but its a pain to get the trailer and take the boat out of the water. Also the only dealer around I trust is 2.5 hours away. Let me know your thoughts on this issue. Thanks
