JDRacing
- Northern Calfornia
- X
So, I'm not even picking up the boat till Saturday, and already looking at the Lateral Thruster and Thrust Vector group buy. One of the things that appealed to me on a competing boat was the lateral thrust capability on the Chaparral nozzles that the 212X doesn't have. And then I came across the group buy from Jet Boat Pilot for the Lateral Thruster, and, without having even put the boat in the water yet, I'm thinking this is something I want to do.
My question: Do I want the Thrust Vector XV with it as well? Does the articulating keel eliminate or greatly reduce the need for thrust vectors for low speed maneuvering (or any other purpose)? And does it reduce the nozzle spray for those being towed on a tube? It's not a huge add on expense to order them, but if the consensus is that they don't add much to the mix on the 2018 212's, then I can always find another (boating) use for the funds.
Recommendations on this greatly appreciated, and thank you.
By the way, I've been sailing off and on most of my adult life, so I'm not new to boats. However, I'm brand new to jet boats, so this is going to be quite a learning curve.
Jeff
Jeff
