2018 AR 240 Newbie Ft. Lauderdale
JWilco
Fort Lauderdale
Hey Jet Boaters! Jesse here. Me and my partner just purchased our first boat! We got the 2018 AR240 in white/blue. We're real excited and will put it in the water for the first time tomorrow. I'm looking to see if y'all have a pre launch checklist you use. Plus I would like to hook up with some local Jet Boaters in tri county area!
Neutron
New Bern, NC
Plug in, batteries charged, life vests in boat, add water and have fun!
Good luck
Stevenpigsooie
Beaver Lake, Arkansas
I have been building this list the last 2 seasons and keep it on the notes app on my iPhone. I use it every time so hopefully I don’t forget anything important. With 3 kids and a 6 lane busy ramp it’s easy to get overwhelmed. Hope this helps with your new boat. Congratulations!
Yamaha Checklist
Home / Storage
  • Life jackets
  • Drinks & snacks
  • Sunglasses
  • Hat
  • Sunscreen
  • Tubes & toys
Trailering
  • Clean out plugs locked in ports
  • EZ locks secured
  • Compartments locked
  • Windshield locked
  • Bimini stowed
  • Tighten tower bolts
  • Unplug battery charger
  • Transom straps tight
  • Trailer lights connected
  • Check tires
  • Tighten winch strap
  • Check safety chain
  • With cover put noodle on windshield edge
Pre-launch
  • Transom straps released
  • Check hardware on nozzles, steering keel, and fins
  • Drain plugs tightened (engine x2, storage, & stern)
  • Bimini top open
  • Steering test, finish centered
  • Throttle test forward & reverse
  • Check engine compartment for fuel leak
  • Battery switches on
  • Keys on
  • Blower on 4 minutes
  • Engine started for test
  • Lanyard pulled for test
  • Blower back on
Launch
  • To ramp then to edge of water
  • Driver releases winch and safety chain
  • Slowly back into water
  • Start engines and reverse until off trailer
  • Check cooling water from ports
  • Fenders on front cleat, bow rail, middle cleat, & tower
Retrieval
  • Trailer into water with fenders at water’s surface
  • Front 2-3 feet of bunks exposed
  • Slowly approach trailer and make contact with bunks
  • Center on bunks then gently power on
  • Connect winch and finish powering/winching boat to bow roller
  • Connect safety chain
  • Pull out of water
Post-retrieval
  • Open engine compartment and check for water and fuel
  • Open all drain plugs
  • Start engines and idle to clear water
  • Battery switches off
  • Keys off
  • Remove clean out plugs, drain water, lock in place
  • Close bimini and secure with cover
  • Windshield locked
  • Connect transom straps
  • Fill up gas
Storage
  • Hang wet life jackets, tubes, and toys
  • Take out trash and potty waste
  • Empty cooler and all food from boat
  • Clean glass
  • Clean seadek & vinyl with all purpose cleaner as needed
  • 303 conditioner on seats, vinyl, & plastic
  • Spot clean carpet with carpet cleaner
  • Spray carpet with deodorizer
  • Leave compartment doors open
  • Fan on carpets
  • Plug in onboard charger
  • Wipe exterior, boat bling as needed
  • Remove clean out plugs, t-handle locked & keep lid raised
  • Loosen winch and transom straps
Maintenance
  • Yamalube silicone protectant on engines, stern metal components, clean out plugs, and drain plugs
  • Grease throttle cables, gates, and keel
  • Wash clean out ports
  • Ring free additive
  • Vacuum
Winter
  • All compartments open
  • Batteries on charger
  • Full tank with ethanol free gas & yamalube conditioner x2
  • Occasionally turn steering wheel through full motion
  • Bug spray and traps around storage
Spring
  • Oil & filter change
  • Spark plug change
  • Tighten all boat screws and bolts
  • Check trailer tire pressure
  • Tighten all trailer screws and bolts
  • Tighten trailer tire lug nuts
  • Grease trailer zerks
  • Wax gelcoat
  • Spray bimini with 303 fabric guard
  • Charge VHF radio
  • Check quality of flares
  • Clean bilge pump screen
JWilco
Fort Lauderdale
Yamaha Checklist
Home / Storage
  • Life jackets
  • Drinks & snacks
  • Sunglasses
  • Hat
  • Sunscreen
  • Tubes & toys
Trailering
  • EZ locks secured
  • Windshield locked
  • Bimini stowed
  • Check tires
Pre-launch
  • Bimini top open
  • Keys on
  • Blower back on
Launch
Retrieval
  • Pull out of water
Post-retrieval
  • Keys off
  • Windshield locked
  • Fill up gas
Storage
  • Clean glass
  • Fan on carpets
Maintenance
  • Vacuum
Winter
Spring
  • Spark plug change
  • Wax gelcoat
  • Charge VHF radio
Wow! That is an awesome list! It will definitely help and I really appreciate it! Thank you!!
njmr2fan
Augusta GA
:Welcome:Great place to learn about your boat and find ways to spend more money! Don't forget to have some extra keys made and find a place to hide a pair onboard for emergencies.
