2018 AR210 First Spark Plug Change
isitsummeryet
Bradenton, FL
Guys I bought the boat last year and I need to do a spark plug change for the first time. I have the plugs but there is no video for it on the TR-1's anywhere that I could find and strangely the spark plug change procedure is not even listed in the service manual. They just give you a torque spec. I saw a video on youtube from Rob's DIY channel but those are different motors. I am not sure if the process is the same?!
Can anyone please help me with how to properly change spark plugs on TR-1 motors?
Much appreciated.
Thanks
isitsummeryet
Bradenton, FL
No one here has ever done a TR-1 motor spark plug change? I thought this was an easy answer to get. Ok I guess i'll try it with my best judgement. Fingers crossed.
swatski
North Caldwell, NJ
I would think the process is the same as 1.8 engine, the TR-1s are kind of brand new in boats and owners may be doing a dealer first change? Idk. It is strange you got no answers. But there is really only a handful out there - brand new 210 and FSH210.
jcyamaharider
Event Sponsor
Event Sponsor
Vendor
Rosebud, Mo
Only difference is there is one less cylinder. Nothing to fear, get on it and go have some fun.
jeff_s
I have a ‘17 AR210 and just recently changed all 6 plugs.
It was easy. It took me about 15 minutes total.
And I found my coil pack bolts were all loose. So I now check them once a week to ensure they are tight.
Maillis
Holiday, FL
FSH Deluxe
Just make sure you have a 6” wrench extension with a magnetized 5/8” spark plug socket and it’ll be easy
isitsummeryet
Bradenton, FL
question, do you put anti sieze grease on NGK spark plugs? And do you check the spark plug gap with a gage?
swatski
North Caldwell, NJ
They come pregapped. Antisieze is like engine oil - personal preference!
Maillis
Holiday, FL
FSH Deluxe
NGK says not to use anti-sieze on their spark plugs. They’re already plated with a coating and the anti-sieze doesn’t really add more protection and may cause you too over-torque the plugs and damage the engine.
