2019 212 Limited S mooring cover
Ron Westman
Nebraska
I purchased a 2019 212 Limited S. The boat will be stored on a boat lift with a canopy.
I would like to have an inexpensive mooring style cover to protect the boat from dirt, leaves, and animals.
I would like the cover to be easy to install and remove from within the boat (boat will be on a boat lift).
Any ideas and links will be greatly appreciated.
Ilmmct
Wilmington, NC 28411
I think the OEM mooring cover is the best way to do. Although this is expensive and somewhat of a hassle to insfall from your lift.
My two cents rationale:
-for boating intensive weekends, you are likely not going to bother putting the cover on each night. Your canopy is sufficient cover, letting the boat dry-out after a day of play and cover install hassle avoidance.
-for longer periods away from the boat, you are going to need the tight fitting OEM mooring cover. No water pooling issues which would likely occur with a less expensive option. A tight fitting cover to insure against high winds and critter intrusion. A good tight fitting cover gives you peace of mind while you see away from your new toy.
Although this moves you further way from your inexpensive objective, the HangTyte system reduces some of the hassle of the OEM anti-pooling poles and makes the lift-based cover installation a tad simpler.
Enjoy your new boat!
