2019 AR 195. Cranks but will not start.
Rising68
Good afternoon, I have 2019 AR 195. A couple of weeks ago I had to be towed off of the water because my boat would not star after sitting on the water for 2 hours. I had everything turned off. The battery showed 12.2 volts prior to cranking but dropped to 11.2 volts during cranking. When I got it back to my house I pulled the spark plugs and they were soaked with gas. I replaced them and it started up with no problem. I thought my issue was a bad battery not giving me enough voltage to fore the ignition. I believed this was part of my problem for the engine not starting. But I do not know what TV drew down my battery to cause it not to start. After this happened I installed a second battery with a switch. I took the boat out on Saturday and left the battery in the both position. I let the boat sit for about 2 hours with everything turned off and it would crank but not start again. After I got towed back in I took the boat directly to the dealer. The mechanic told me all spark plugs had water on them. He said he replaced the plugs and it fired back up. I was not good with this response as I had the cranking but not starting issue happen to me 3 times. How does water get on all 4 spark plugs. Does anyone know how many y cranking amps you need to get these motors to fire. Has anyone had a similar issue. I honestly thought it was an ignition issue, but after being told water was on all spark plugs I'm confused at how that can happen. The ks for your time
4x15mph
Downingtown, PA
It could be the safety lanyard switch and it sounds electrical. I am not quick to think you have water on your spark plugs unless your boat bilge doesn't work or you have some other consideration since this is a 2019. I would also look at your 2nd battery install. Last, I would consider another dealer unless you are saying this is one of the better one's we read about here. Who is it?
jacoviii
Independence Mo
255XD
You would need to do another wet test on the water with engine hatch open to see if any hoses have a pin hole in them.
jacoviii
Independence Mo
255XD
Yes lanyard or clean out hatch switch but both should not let the motor crank.
Rising68
I appreciate the responses. I purchased the boat at Barnies in south Tampa. It is still under warranty. The mechanic told me it had water on all spark plugs. I know when it broke om me the first time it had fuel on all plugs. I've never heard of water on all plugs unless I had a cracked head or cylinder in all 4. I personally did not pull the plugs and look at them. I agree I believe it's an ignition issue. Very frustrating.
Rising68
It's at the dealer now. I will let you know what they do to fix it. Thanks again for the responses
Rising68
How do you read codes on these boats? Do you need a code reader or can I check it on that display screen.
Rising68
It did not have any external leaks. Thanks again
Rising68
It could be the safety lanyard switch and it sounds electrical. I am not quick to think you have water on your spark plugs unless your boat bilge doesn't work or you have some other consideration since this is a 2019. I would also look at your 2nd battery install. Last, I would consider another dealer unless you are saying this is one of the better one's we read about here. Who is it.
Barnies in South Tampa thanks again
4x15mph
Downingtown, PA
If the safety lanyard is disconnected, the engine still cranks but will not provide fuel and fire up. The rear hatch switches will not allow the engine to crank over
d_coyne1984
Chanhassen, MN
The boat will actually crank without the lanyard attached. It got me panicking a couple times...
dshscarab
South Florida
AR195
Hey just a thought, when you got towed back in, did the tow boat go fast? Did water enter the engine from the tow? Or maybe, the mechanic said water but noticed the plugs wet and just called it wrong.
marcham
Comox, BC
AR195
Plugs would be wet after lots of cranking. Frequent problems in outboard are the neutral position sensor and the kill switch. Did you check both of those? Next would be a weak battery. Finally, bad gas would be my last most likely fault in a new boat.
On this boat, the rear deck hatch switch should also be tested.
The note above about towing is important. Towing above a few knots could have flooded the engines with water. Are you able to use a pump to sample the oil to check for water?
How many hours on the boat? Did you refill somewhere you normally don't? Has the boat sat for an long time?
d_coyne1984
Chanhassen, MN
Very good point on the water in the engine! Towing without the fresh water intake line clamped off is risky. You can get water backing up from the exhaust system into the engine without any exhaust pressure to force the water out.
Cobra Jet Steering LLC
Vendor
Florida
I also have had issues with the throttle positioning switch , same symptoms I move the throttle a bit then retry and it usually works after that so next time move the throttle back and forth a bit and retry. The positioning sensor will not allow spark if the throttle is not in neutral to avoid accidents, thus the wet plugs but not water FUEL
Rising68
When I got towed back the guy wasn't going fast. For water to be on all plugs would all exhaust valves need to be open. I know the first time this happened it was fuel. When the lanyard is not installed does it just turn off spark or both fuel and spark.
Rising68
The boat has 20 hours on it. The first time it broke it had around 10 hours. It may have entered during the two. But it was on all 4 plugs according to the mechanic. I'm tired of this brand new boat breaking. Im sure it's something simple. How much does your boat volts drop when you crank it? Mine goes from 12.2 down to 11.2 cranking. How many volts do you need for ignition to light. Maybe a bad cell in a battery? The last t iij me it broke I accidentally left my batt switch in both. I still have the first battery installed in the number 2 position from when it broke last time. The boat sat for a week. By the way I have the same color boat as you.
zipper
Boston Whaler
marcham
Comox, BC
AR195
It disables spark only.
If there's enough battery to crank, there's enough for the ignition.
Do you have kids? Could they have messed with the controls ?
dshscarab
South Florida
AR195
I believe spark only which in fact would give you the wet plug problem. Let us know what the dealer finds.
