2019 AR195 Seat Lock
thegame3202
AR195
I've noticed that if I adjust the driver seat forward or back, it never actually locks in position. As soon as I take off, the seat goes all the way back like it slipped out. In looking closer, I think the bar with the notches doesn't go all the way back to vertical, so it slips out once you take off. Does anyone else have this issue?
It looks like there is a spring that is supposed to pull it back, so maybe the string isn't strong enough? If I push the notched bar back to vertical, it seems to hold. But I don't want to crawl under my seat each time :p
Any ideas? Thanks!
Mac’nCheese
I also have a 2019 AR195. Mine definitely locks into place. Is the little triangular handle under the seat in the bottom position, or is it tilted to the side?
thegame3202
AR195
Yeah, I've tried playing with that a bit too to make sure. Of all of the things to be out of whack, this is a weird one haha.
S1LV3R4D0
Knoxville, TN
AR195
Mine adjusts forward and back and locks in all positions. Sounds like you got a gimpy seat adjuster. Warranty that bad boy!!
