2019 SX195 Chartplotter / fish finder
Michal
Hampstead, NC
SX195
Hi everyone,
Embarking on a project to add an Lowrance Elite Ti 7. Started working on it yesterday. I removed the phone holder and drilled a hole for the power and transducer wire right into the dash. Will post more when I'm done but just wanted to share.
IMG_20190310_173655110.jpgIMG_20190310_181955537.jpgIMG_20190310_195218543.jpgIMG_20190310_182019414.jpg
Rob2336
Yuma, AZ
Very interested in seeing how you do the rest. I have the same boat and want to put in that same unit.
Michal
Hampstead, NC
SX195
I will definitely post updates. Busy week at work, it may not be until the weekend until I do more.
Michal
Hampstead, NC
SX195
@Rob2336 Sorry for the delay on this. I completed the install. Ended up ordering the blue see clam for the wire. Drilling a hole in a brand new boat was a little nerve wrecking. I ran the transducer cable on the starboard side to the instrument cluster. Tapped in to the "cigarette" lighter for power. Been on the water 2 times with it so far and I'm able to get a clear sonar signal up to 25mph. The transducer may need to be lowered a bit to get a clear picture at higher speed but then again I don't want to create a rooster tail with it and have too much drag on it.
@Rob2336, have you completed your install yet?
1- Blue See Cable Clam
2- used a transform saver for the transducer.
3 attached and leveled the transduce
4 secured the clam
Rob2336
Yuma, AZ
4 secured the clam
I havent even bought one yet. I was waiting for your review. I'm boat mod illiterate. I'm super nervous about putting any holes in my boat.
Michal
Hampstead, NC
SX195
No need to be :) get the same clam I got and you'll be fine. I promise. If you have any questions hit me up on FB.
Rob2336
Yuma, AZ
Where did you install the clam? I've found the parts you speak of.
Michal
Hampstead, NC
SX195
The white ring to the left is the clam. The white ring to the right is the drain.
Michal
Hampstead, NC
SX195
Well dang... That's crazy j can see them. Let me try to upload again. IMG_20190323_104627043.jpgIMG_20190323_104630231.jpgIMG_20190323_104632769.jpgIMG_20190323_104640971.jpgIMG_20190323_112933567.jpgIMG_20190323_114742886.jpg
Michal
Hampstead, NC
SX195
Rob2336
Yuma, AZ
Alright, I've finally done it myself. I used alot of the things you did, but tweaked it some. I haven't mounted the transducer yet because the pad said to wait 18 hrs, so I'll mount it after work tomorrow.
Rob2336
Yuma, AZ
I put an amp in for the factory speakers as well. Also a second battery and switch for 2 Batts as well. When I finish it up I'll post more photos.
