2019 Yamaha 242x e problem with 12 volt plug on dash not working
Leif
I have a Yamaha 242x e 2019 I think I blew a fuse since of 12 voltacigarette lighter plug on dash will not work I need help on finding where the fuse box is so I can check the fuse please help
tek4fun
Maryville, Tennessee
The fuse box is mounted on the same bulkhead that the battery switches are on. You will have to cut the zip tie on it, so you can open it.
107958
The fuse you need to check is the one with the orange box around it.
Leif
Thanks going to check that now
Leif
Thank you for the help tek4fun that was it blown fuse but with out your help I wouldn't of have found which fuse and where it was at
ZGhost
Minnesota
Good to know where the fuse box is, I would have never guessed. Will take a peak at mine when she is back and out of hibernation.
