Botchco
- Louisiana/Mississippi
- FSH
Okay guys. Looking for some advice of what to think and how to deal with these symptons that just popped up this weekend.
1. Symptom 1 - yesterday after running boat from launch to dock ( approx 27 hrs total run time)and leaving it docked fro an hour or so, I went to take the kids tubing. Upon attempting to depart I cranked up the port engine and went to start the starboard engine. However it appeared that the engine was not in neutral position so I adjusted the lever back a bit and when I tried to put it forward back into the neutral slot it was stuck. I ended up having to get in the water and manually push The jet wash deflector up towards the neutral position. Upon doing that I was able to start the engine. As I left the dock all of a sudden my port engine cut out at about 1500 RPM. I quickly Restarted the engine, and let it run for a few seconds before re-engaging the speed control to go forward. At about maybe 3000 RPM I felt a sudden power loss and look down in the port engine had cut out again. I quickly thought to check the clean out As I know from past experience these have to be firmly engaged. I reset the clean out cap and went about restarting the engine. And we were able to travel along probably at about 16 mph till we reach the middle of the lake to let the kids get in the water. I left the engine Idol and again all of a sudden the port engine cut out. It did this a few more times throughout the day even as I checked the hatch in all of the switches to make sure they were functioning properly. Eventually The issue lessened and did not notice it again as we put the boat up for the night.
2 Sympton 2 - today was pretty much a rain out so I decided to bring the boat back to the launch and put it up in storage. Upon starting the boat I crank the Portside engine which fired up perfectly. As I cranked up the starboard engine however immediately the engine alarm came on.I know from experience two weeks after I got the boat and what I’ve read hear this can occur from time. I shut the engine off waited a few seconds start again only to have the alarm again. However I did this three more times and low and behold the alarm goes away. However on One of the restarts as I was sitting there trying to clear the alarm my port engine cut out again.
Sorry for the long winded explanation of the symptoms but I would like any feedback on similar experiences and possible fixes you may have seen or heard of. Thanks in advance.
