Chucksx190
- SX
Okay I have a 2020 sx240. Have about 50 flawless hours on it. Took it out yesterday and the bluetooth all of a sudden stopped working and it flashed a joistick communication code real fast. So I stopped the boat and disconnected the battery and reconnected, and the bluetooth still did not work but the joystick code did not come back. Almost finished with my round trip about 75 miles in total and as I'm about a mile away it flashes the joystick communication code again and then a gps communication code then a code spu25-15. Disconnected the battery again and reconnected. Took off again and about 30 seconds later it flashed all codes again then the alarm just stops and it goes back to normal. It kept doing this every 30 to 90 seconds the rest of the way home. I checked all the battery connections and all are tight and no corrosion. The issue still is there today. Any ideas on what the issue could be. I would like to avoid the dealer as I'm sure it would take months to fix, and my 1 year warranty ran out 2 days ago. I do have the 3 year Yamaha extended warranty.
