mrcleanr6
- new jersey
- 275SD
ok, so i took delivery this afternoon of my black cherry 275sd. what a difference since i was coming from an 08 232 limited. i took it out for a quick 45 min spin after doing all my paperwork at the dealer. i have read i think all the 275 threads on this forum and i do know there have been some concerns in the past on a few different item so i took note of these and will give some feedback on those.
#1 the drive (paddles) on the steering wheel. i always thought this was a cool idea but maybe a little gimmicky. let me tell you that this is the one of the best things for controlling a boat i have ever used. it truely is unbelievable how awesome theses things are. the control you have around the dock is amazing. i am able to maneuver a 27 foot boat as easily and exactly like my waverunner. took me 5 min of using the system and it was like second nature. cant say enough how awesome it is and i totally recommend getting a "D" model in any size boat.
#2 the stbd oil filter. there has been concern about being able to access it because the stbd engine is stuffed under the hatch and the filter is on the left side. i am putting a pic below showing that this is of zero concern. the filter is super accessible. far more than my fzs. its literally right there in front of you.
#3 its nice to see yamaha put all stainless latches in the boat instead of the plastic/aluminum ones
#4 the tower and tow point. for 2021 yamaha added a tow point onto the tower which is great. there is also still the low one on the rear grab handle but im sure this will make way too much spray since its only 4" off the water. there were also reports of the tower and hardtop shaking and being unsturdy. this has all been fixed. there was a 2019 on a storage rack near my boat so i can compare. the 2021 tower has been completely redesigned. it is now super beefy with heavy tubes and braces. the tubes have to be 2.5" dia. i cant come close to getting my had around any one of them. tubing work is fantastic. its really night and day from the old one. i took a few pics below of the tubing work they did. its really nice. from the pics you cant really get a feel for the size of them or how beefy it is.
#5 connext chart plotter. i think this applies to all models of our boats but many in the past have said the system is slow and that its set to north is always up. i can confirm that north up is not the case any longer. you can now have north up or boat direction up just like on the nav in your car or truck. i have not changed or updated any maps as of yet but in stock form i experienced no lags in the system. for the 1/2hr i used it, i had no issues with the plotter function. i will update the maps before next season and maybe that will add more data. not sure on that yet.
#6 fit and finish. i work for a yacht and high end center console company. i have been on and around very expensive boats my whole life and i saw no issues with fit and finish. with all the delays getting the boats out and covid, i saw no evidence of anything being rushed or $hit out the door. the interior is very nice and of very good quality. the vinyl material is night and day better than on my 232. vinyl is much thicker and more heavy duty.
#7 hinged seats. i dont know if yamaha only does this on the 275 or they started this on older models but the hinged seat cushions are so nice. no more trying to yank up cushions to get access to the storage under them. i used to have to open the engine hatch just to get the cushion off to get access to the battery switches because the seats were all locked together. what a pia. the hinges on these seats are very sturdy and strong as well. i assumed they would be some thin stamped metal but they are made of thick alloy.
#8 wiring. wiring and wire management is one of my pet peeves. this was absolutely atrocious on older yamahas. when i look under the dash on my 232 i almost have an anxiety attack. i can even open that door. not sure when it happened but at some point yamaha really cleaned that up under there. that is probably mostly due to the connext screen. i would say its not completely to the level i would like it but its not a 2 mil dollar yacht either. definitely acceptable though
i will update this more as time goes on. i am going out tomorrow for a few hours so im sure i will have time to get into it more and give other feedback. these were just my initial impressions. if there is anything specific someone would like me to look at or get pics of, let me know.
