NEW MODEL INFO 2021 Yamaha AR250 Lifestyle Images
Bruce
Royal, AR
Please click the thumbnails to enlarge.
AR 250_3733.jpgAR 250_3740.jpgAR 250_3748.jpgAR 250_3770.jpgAR 250_3774.jpgAR 250_3802.jpgAR 250_3821.jpgAR 250_3877.jpgAR 250_3916.jpgAR 250_3936.jpgAR 250_4072.jpgAR 250_4096.jpgAR 250_4139.jpgAR 250_4149.jpgAR 250_4151.jpgAR 250_4152.jpgAR 250_4388.jpgAR 250_4400.jpgAR 250_4423.jpgAR 250_4448.jpgAR 250_4472.jpgAR 250_4483.jpgAR 250_8077.jpgAR 250_8094.jpgAR 250_8104.jpgAR 250_8124.jpgAR 250_8132.jpgAR 250_8134.jpgAR 250_8149.jpgAR 250_8169.jpg
BoostEasy
Does anyone know where the additional weight of the AR250 vs Ar240 is coming from? Looks to be about 374lbs additional and the boat only increased by 6". I know some will be from the larger gas tank, but did they increase hull thickness on this model? Also, does anyone know if this model will have the swim up seating? Thanks!
tkeru408
252SE
No swim up seating on the AR250.
toddarizona80
Any pictures of the black with green trim?
HangOutdoors
Royal Oak, MI
My thoughts so far.... And this would be the one that I look at the AR250 hopefully at a boat show.
1) I like the blue, do not like the White Tower.
2) What is up with how the tower attaches to the boat? Gaps and pointy on the front and back of where the tower meets that mounting piece. How does that fold with the windowshield.
3) Screen.... C,mon, could of went up to the next size.
4) I like the wet storage, perfect spot for it. Alot of it now with the lower compartment.
5) Concerned about the table placement behind driver.
7) Would like to see Bimini Top up
6) Like the port Storage area and netting.
SCP1
DeForest, WI
212S
Just noticed something, it appears no more stainless rubrail?
906Tony
Escanaba Mi.
That screen being downsized in that frame is a joke, just makes you feel kinda like you got the watered down version 🙄
Beachcampin
Jacksonville, FL
Found a vid here that seems to show this seating.
tkeru408
252SE
As best I can tell, the videos they're showing aren't specific to one model; e.g. on the AR250 page the video shows several of the 25 foot models. Me saying the AR250 doesn't have the swim up seating was based on the using the compare function on the website (see attached screencap), but who knows if that info is correct or not either.
SCP1
DeForest, WI
212S
Keep in mind the hull is deeper.
KCAR250
Can anyone actually verify the weight of the AR250? On the website it says 4034lbs but in another section it says over 5k lbs. I need to get a proper lift but can’t figure out the empty weight!
