210 Spreader Lights
Tailwaters
St Joseph MI
Looking to install a couple spreader lights on my 210 with a canvas top. Just wondering who else has done this and if you had any issue drilling through the tubing and not chipping out the powder coat? Planning on using a clamshell style mount to make things nice and clean plus adjustable.
Thanks
anmut
212S
I would think that it would be just like adding speakers - probably use some blue painters tape over the spot you're going to drill to prevent damage to the powder coat.
Maduro
Crystal Beach, TX
Definitely use blue tape and run the bit backwards. Once you’ve removed some material go forward. Use the sam process on gel coat.
FSH 210 Sport
Tranquility Base
Came across these yesterday... pretty much what I’ve been looking for. I like that they are dimmable, and have red light to maintain your night vision. These lights only use two wires, toggle on/off to set light level and again to change colors. They’re available in blue/white as well.
Jet Boat Okie
Lake Texoma
Has anyone installed lights on a 210 that they are happy with? I had purchased some nlights and mounting hardware on Amazon, but didn’t end up installing them because of the hassle and uncertainty of performance.
If anyone has a success story installing lights please share!
jocolo21
252SE
I installed led spreader 5" to my 242 for my Bimini trip, plain and simple i couldnt see they were so bright that i ended up taking them off, might be good for fishing at night but to go in and out of the south bimini chanel i couldnt see crap
Maduro
Crystal Beach, TX
[/https://youtu.be/SYkB8mma-oc
Jet Boat Okie
Lake Texoma
lazergeek
South Florida
This guy has some pretty good stuff!
I dont like the idea of that many holes in that location of the rear tower. probably weakened it.
