Jameson Clark
- Laurens, SC
- X
Just got a new 2017 212X and took it out for the first time last weekend. This is my first jet boat and my last two were sterndrives. Three things I noticed that I wanted to get an opinion on.
1. The boat seemed to pull left anytime on plane. Didn't matter how it was loaded, it always pulled left. Is this normal or does the articulating keel need to be adjusted or what?
2. On plane there is a ton of play in the steering, you can turn the wheel about 1/3 turn each way with no change in direction when on plane.
3. When in reverse, with the throttles at the same point, one engine revs MUCH higher than the other. I have to give the left engine substantially more throttle for the rpms to match.
Thanks for any help!!!!
