242 limted s e bimini
BakedZiti
Milledgeville, Ga
Hey guys, im looking at picking up a 2018 Limited SE, I have major concerns about having this boat on my lake because it has a few low bridges and im not sure the boat will fit under them even with everything folded down. I plan on getting some real world measurements of the bridges this weekend but Im wondering if there is an aftermarket bimini available as opposed to the big cage that it comes with? The boat will be located on Lake Sinclair so if anyone has any real world experience with this boat on that Lake any input would be appreciated!
AboveTheBest
Bloomington, IN
I can’t help you with your questions, but if you switch to a smaller Bimini there will be plenty of folks lined up to buy your E-Series Bimini.
I’d drive down to GA to swap you the Bimini from my LS if you want a smaller one :)
BakedZiti
Milledgeville, Ga
Haha, well I would hate to have to lose it but if I can't get under bridges I lose a lot of the lake
AboveTheBest
Bloomington, IN
Hopefully you can make I work!
Mainah
Chapin, SC
Yep I would be one of those guys lined up. I would even custom install 12v linear actuators to turn it into a power tower for him.
AboveTheBest
Bloomington, IN
Yeah, well I would do that too, but I would also make him a custom top out of baby seal fur to go along with it...
Mainah
Chapin, SC
I think you are seeing that the e series tower/bimini is a very desirable item, particularly in the south. Do everything you can to try and keep it. If you can’t the best way to change to a LS style is to just swap the whole tower with someone.
BakedZiti
Milledgeville, Ga
Hah, funny stuff guys, I might actually take you up on that actuator..looks like boat covers .com has a Bimini that I can clamp on to the tower...
Mainah
Chapin, SC
The e series tower is a bit different up top in order to support the bimini frame. The true easiest way again is to swap (you getting something out of it as well) with someone with the same color LS tower that you want. For instance mine is gray and probably would not go well with some colors. I would shy away from those clamp on biminis. Ask @Speedling about that.
biffdotorg
Pelican Rapids, MN
To be realistic, isn't the tower the real issue, as it is as tall as the Bimini when the Bimini is set in the lower position. If you can't fold it up and tip the tower down for your low bridges etc, the bimini size will be immaterial.
I do realize the trailing edge of the bimini when fully extended on these models looks to be slightly higher than the top of the tower, but it does have a lower position as well. You still have the height of the tower to deal with. Swapping a Bimini does not address that you are still tipping the tower.
Mainah
Chapin, SC
But how do you drive an eseries with the cage folded on top of the tower? And even if you can what do you do with the crew? This would be one place where a LS or SX has an advantage. Will be a PIA no matter how you do it though as even an LS or SX would need the bimini stowed.
Hopefully some with an e series tower can chime in.
Speedling
Cedar Lake, IN
SS
Yeah mine had allen screws that just pinched th poles on. I drilled and tapped it with some thread locker. Much better now!
Hilario Perez
Kissimmee FL.
If you would like to sell it I’ll be interested please put me first on the list.
BakedZiti
Milledgeville, Ga
Thanks for the feedback, I will take some measurements on Friday and see if even have enough room with the tower folded, no Bimini... I'm teetering on dropping the money on the 2018 limited se or just doing away with the tower and going brand new sx240. I don't NEED the tower but I like the higher trim level
AJack
Tampa 33621
I'll do you a favor, my SX240 doesn't have a strange contraption on top. I'll swap you so that you won't have to deal with it anymore.
BakedZiti
Milledgeville, Ga
How do you like your sx240? Any regrets?
Hilario Perez
Kissimmee FL.
I do a lot of boating with two good friends of mine with 2 AR240 And the boats are exactly the same motor wise hallways cabin wise everything I like mines a lot but I like the Tower also because I’m gonna keep my eyes for a while so I’m trying to locate one.
AJack
Tampa 33621
I went with 24' because we wanted the capacity to hold two families (which we have - 4 adults and 6 children). We don't do any water sports, so the tower wasn't a need. I do think the tower adds a bit of sportiness and provides a high mounting position for a VHF antenna.
Rivergal
I also wish I could swap out the cage top on my 242SE for a Bimini top as my boatwell roof is low enough that I can’t lift my boat completely out of the water. Close to being completely out, but not 100%. It’s a tight fit and it’s a pain to have to try and level out the cage. Not that big of a deal to put the tower down - but the cage adds almost another foot to the top.
