1. Welcome to Jetboaters.net!
242 two way radio mounting location
Discussion in 'Yamaha AR240, SX240, 242 Limited / S / X/ E-Series' started by NORCAL-GAS, Aug 2, 2018.
  1. NORCAL-GAS
    NORCAL-GAS Active Member
    110
    Ratings:
    +65 / 2
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    I'm wanting to mount a non-handheld two way radio to my 2018 242x. I'd like to see some pics of what other 242 owners have done to mount their radios. If you also could describe any install tips, radio advice, or other FYI's, I would appreciate it.
    I should mention that I'm looking at the standard horizon gx1700 as my top choice right now. Thoughts?
  2. Captbob
    Captbob Jet Boat Lover
    86
    Malvern, Pa
    Ratings:
    +26 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Here is where I put mine.
  3. seanmclean
    seanmclean Jet Boat Junkie
    1,187
    Medford, NJ
    Ratings:
    +1,242 / 41
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    Newer boat, but same location recommendation
    [​IMG]
    [​IMG]
  4. NORCAL-GAS
    110
    Ratings:
    +65 / 2
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    those look nice, but it seems like my long legs would hit it....
    I think that does seem like a logical place though.
  5. BBottoms
    BBottoms Well-Known Member
    74
    Buffalo, KY
    Ratings:
    +82 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    I used a piece of 1/4" starboard and mounted where the factory storage tray is behind the throttles. I can remove 4 screws, unhook the power and antenna cables and put the tray back when running on my local lake where I don't need the VHF.
    • Like Like x 1
    • Winner Winner x 1
  6. NORCAL-GAS
    110
    Ratings:
    +65 / 2
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    That’s what I was looking for. Good idea. I’ll prob do that. Unless someone has an idea for the area to the right of the throttle.
  7. Captbob
    86
    Malvern, Pa
    Ratings:
    +26 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    I put mine under the dash as shown above and my height is 6'0" and I have never hit my leg or knee for what its worth.
  8. AJack
    AJack Active Member
    110
    Tampa 33621
    Ratings:
    +41 / 4
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    @BBottoms I really like this installation, very clean and out of the way. Which radio is that?
  9. BBottoms
    74
    Buffalo, KY
    Ratings:
    +82 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    It's a Standard Horizon GX1700. Many fixed mounts that have the ability to be flush mounted could work though. I had to buy a separate flush mount kit for the GX1700, which was just two small stainless brackets. I think it was $15 or so.
    I was a little worried about the built in GPS in the radio picking up satellites but it seems to work fine and the unit is probably as or more exposed to the sky than an under dash mount.
  10. Captbob
    86
    Malvern, Pa
    Ratings:
    +26 / 0
    Boat Make:
    Year:
    Boat Model:
    Boat Length:
    My Horizon 17oo (GPS) works fine under the dash. It takes a little longer to get GPS signal when the winter cover is on.
Share This Page
