- Raleigh, NC 27614
- 242X E-Series
Since we got soaked during last years trip to Bimini on the way over, and once while out fishing, I decided to use an old piece of vinyl I had left over from screening in my porch to attempt to make a temporary screen from the bimini frame down to the windshield. I took the vinyl out yesterday to the boat to see if it was wide enough (it is 2'8") and it is plenty wide. What was interesting was that I was able to stuff the vinyl up under the bimini cover on the bimini and it held in there really well (the strap that hold the bimini on helps to keep it pressed tight). So my first plan is to simply stuff the top under the bimini and then used bungee cords to hold the bottom down to the center of the windshield, perhaps the back edge of the seats, and to the mid ships cleats. I will take this out tomorrow and see if it holds up to a 20mph sustained wind test. Since I've made this from stuff I have laying around...this is zero cost so far.
Here is a photo of the vinyl thus far....the black edge will be the bottom edge. I use gorilla heavy duty gaffers tape along the edge to strengthen it, then hammer in grommets through the vinyl and tape.
My back-up idea is to put snaps along the bottom edge and find the appropriate snaps for the top of the windshield. I may do this later (as I can cut it to fit this approach if need be). First problem I have though is not knowing which snaps fit the windshield....seems there are 7/8s and 3/4 inch sizes. But since this will get very limited use I may just stick with the bungee approach if it works.
EDITED IN Feb 2020>>>
-I have learned that there is no need for any grommets at the top because the bimini itself holds it in place with no trouble at all. Only the bottom edge needs grommets.
