HangOutdoors
- Royal Oak, MI
Sorry another battery thread.......
I have been reading about Second Batteries in the forums here. I can 't seem to find and work out exactly what I want to do and how to do it.
I have a 2020 AR210. It has one battery that came with the boat. It is sunken in under the seat with a cover. It appears that there is room for a second battery in the sunken in area. I would like to add this now. Additionally I will be adding a third battery sometime this summer for a trolling motor. So whatever I do know I want to be on that path. I have seen the Add-A-Battery Kit but I am unsure if I should do that knowing that I will need to add in the third battery later. I don't want to buy and replace, just augment as time rolls on if possible.
1) I haven't purchased the second battery yet, but I want something Solid. It will be my house battery and of course a backup to start the engines if needed.
I have purchased and have in my garage the following items:
ProMariner 44021 ProSportHD Series Battery Charger-20 Amp (Plus)
NOCO GCP1E 15 Amp 125V AC Port Plug Power Inlet with 6-Foot Integrated Extension Cord (dreading the day that I need to drill a big hole in the boat).
For Emergencies I also have this, fully charged and in the boat.
NOCO Boost Plus GB40 1000 Amp 12-Volt Ultra Safe Portable Lithium Car Battery Jump Starter Pack For Up To 6-Liter Gasoline And 3-Liter Diesel Engines
I know I need a switch for the batteries and I am unsure which one to buy, knowing that I will have two batteries now and add a third one later. Also what exact battery should I purchase for the second battery. Looking for advice and recommendations. I don't mind manually switching between them for charging during running if that is the best way.
Also, in very succinct terms what should be wired to which of the two batteries. I have read a bunch of different opinions and implementations.
Really do appreciate all the info on these forums and the advice.
