- Corinth, TX (DFW)
My 1998 Avalon hit 400k in November, I should have updated my original post but past on it,
https://jetboaters.net/threads/333-333-miles-edit-made-it-to-350-k.1845/
It was still my daily driver.
The last few weeks we've had some 20 degree weather overnight, in the morning I would hear a tick that I chalked up to a cold engine and thick oil as the sound would go away once it warmed up.
This morning took my wife out for breakfast. The car died just out of the driveway, restarted easily and died again at the next stop light. I was thinking bad fuel or just cold weather gremlins or mice chewing on the cables interrupting the spark as it sounded ok.
We made it about 5 miles to the restaurant where it died and didn't want to restarted, it didn't even sound like the high wind of the starter but a weak spin. It started after two tries and we started back home, about half way heard a loud clunk/grind and immediately lost power.
It appears my timing belt pulley on the cam shaft broke off. It looks like the actual cam might have sheared in half ??
This picture is from away, you can see the pulley has shifted rear (and torn the plastic housing)
This is a close up of the shaft area
I've never seen a cam shaft or replaced a timing belt. Does this look like the cam shaft sheared or did the pulley just rip off ?
@buckbuck @veedubtek @gmtech16450yz @betterwhenitswetter @zipper
