meegwell
- Central Virginia
- 242X E-Series
This is related to another thread I started recently and a common question of when should the bilge go on: How does a large amount of water get in the engine compartment in a day of rain? Uncovered, wet slip. In doing all this bilge research (haven't solved the orginal question of it not working when key is off - batteries on but I have things to check there) there are many related thread and it caused another question to come to mind.
I had about 6" of water in the engine compartment, maybe more. If all the deck rain drains through the scupper, how did so much water get in the engine compartment? I turned the key on and the bilge immediately came on and drained it all (took a bit of time). I hope to solve the issue of bilge not coming on without key on but now I am just curious how the hell so much water gets into the engine compartment? Wondering if there is something else I should be checking.
Thanks all, been a learning experience and this issue I need to get straight.
