WiskyDan
- Jackson, WI
- 242 Limited S E-Series
So I bought a 2006 Yamaha SX230 at the end of last season and have it dry-stacked on Lake Winnebago in Oshkosh, WI. When I'm done with the boat I tie it up at the dock, put the mooring cover on, and away I go. What I'm concerned about is that since it's still in the water I need to leave the battery switch in the on position so that the bilge pump stays powered until they pull it out and re-rack it. If I'm only out on a Saturday it's possible the boat may sit at the dock until Monday morning which concerns me a bit since the battery will be discharging for what could be 36-40 hours.
I talked the the service guy at the place it's dry-racked at (they're a full service dealer) about a second battery and he feels that since I only have the factory stereo and a Garmin chart plotter/GPS drawing power that a second battery would be a bit of a waste. He recommends that they set it up so that the bilge pump is wired directly to the battery so that I can turn the battery switch off when I'm done to decrease the discharge. I spoke with the service guy at the Yamaha dealer where I bought the boat and he said that this would be fine - it's how he's seen some boats set up in the past. If I were to go this route I plan on buying a Noco Boost Plus GB40 and bring it with me whenever I use the boat - for piece of mind:
I don't have a problem spending the money to add a second battery (was told it would be about $500 from the dealer) but I'm not sure it makes economical sense to put it on an older boat if I plan to buy something newer in a couple years. Thoughts?
NOCO - 1000A Lithium Jump Starter - GB40
The GB40 is a portable lithium-ion battery jump starter booster pack that delivers 1,000-amps for jump starting a car, boat, trucks and more.
no.co
