Welcome to Jetboaters.net!
I am not an electrical engineer but I had run wire left over from when I had the house built. When I upgraded the stereo the audio guys told me to replace all of it. They said that for d/c you want lots of strands and for a/c large strands or solid wire is preferred. Something about resistance. I am not sure if is was right or not maybe someone will chime in and explain it to me also.
from what I understand DC voltage requires more strands because the electrons travel on only the outside of the wire. The more strands equals more electrons traveling. This means that a very large gauge solid wire will not perform the same as a smaller gauge wire with many strands.
I work with sever PEs (professional engineers, two of them are building their own electric cars at home), they all say the same thing, dc the more strands the better because the current runs on the outside of each strand so more strand means more surface area / less resistance. They also said Home Depot and lowes are great places to get good wire cheap. If you want something that looks good and performs well go with monster cables but be prepared to pay the premium for good looking cables most which are rarely seen.
Sometimes you can find cheap car audio amp kits. The wire is often chinese made but in most cases wire is wire and it is decent quality. It is important to calculate the "real" ampacity of the amp. Often I see guys sizing wire for their "800 watt" amp and when you look it has a 25A onboard fues. Cam.
Basically, I just wanted to make sure I bought cable that if it ever caused an issue (like burning the boat down), they couldn't blame the cable I used, it was marine rated, etc. A little more money maybe, but a little piece of mind too. Was a quick ship and I'd do business with them again.
